Noob fail.....
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Noob fail.....
    Posted: 21 May 2011 at 12:48pm
Why do these people not how to propperly "unstuck" a loader tractor? I'm tired of seeing this happen. last fall I saw a loader tractor stuck in some relatively muddy dirt. Stopped and showed him a trick or two with that big bucket.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 1:08pm
I read the manual on my Mta and it said Not to do that! Kinda laughed when I read it because of all the times Iv seen people do it!
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 3:24pm
it doesnt even looks like he should be stuck. that hole is small.
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 4:06pm
Looks like a good way to tear off a fender too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 4:06pm
probably has his bucket full of wet dirt and not thinking enough to dump it
German Shepherd dad
#WD234847
#WD88193
Okiejohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okiejohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 4:22pm
Gotta agree. WD, dump the dirt, then use bucket to lift front end weight off ground, try to skid out on bottom of loader bucket, if that don't work, turn loader to full dump position, lift front of tractor off ground, roll bucket back while trying to back out. Simple!
Be sure you are right, then go ahead.--Davy Crockett
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 8:30pm
Stupid is as stupid does....
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 9:35pm
So that how fenders get bent up!!! I have to "bucketwalk" everytime  I bushog  down near my creek. Farm boys just take for granted everyone knows this stuff.......
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 9:41pm
That's a 190 with a snap coupler hitch, kinda unusual.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 10:55pm
I've had to go to bil a few times  when he rents a skidloader and gets it stuck, I tell him a skidloader is never stuck unless you can't reach bottom, he just can't seem to coordinate.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 12:01am
He wouldn't be stuck if he wasn't running slicks on the back of a loader tractor!!!
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 2:28am
Is having to put the dirt back in the bucket really that hard? I think it would be easier than putting a new fender on the tractor.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 2:04pm
Yeah, that's definately a FAIL.   Fronts aren't mired in, so it's time to use the bucket.
I've got a 12hp Cub Cadet with a Workhorse FEL, and I've never had to try this stunt... I just do what everyone else does... full dump, down, and curl... lift up, full dump, down, and curl... it'll walk itself back out.
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 6:37pm
I had my MD stuck in mud up to the axles. Trying to rock it out didn't work so I just got another tractor to hook to the back and pull it out. It broke my 4 ton come-a-long ( I always thought it was cheap anyways). We don't have a loader tractor but I always think its better just to in that situation to at least get a shovel and make the hole "bigger" and the slope less steep and try to back or pull out.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 7:54pm
[QUOTE=Okiejohn]Gotta agree, if that don't work, turn loader to full dump position, lift front of tractor off ground, roll bucket back while trying to back out. Simple![/QUOTE
Years ago I was at the County Land Fill. A guy there was operating a crawled loader, and was slightly stuck. I told him to do that, which he did and pushed himself back a ways, but instead of lifting the loader next he uncurled the bucked and pulled himself back to where he was. I just turn and walked away. You just can't fix stupid.
Dusty
