180 power director |
Post Reply ![]() |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 32612 |
![]() ![]() ![]() ![]() ![]() Posted: 20 May 2011 at 6:31am |
My 180 has been worked a little harder recently pulling disc and drill, the power director seems to be dragging more than it used to; when I come to a stop in gear but disengage the director to keep the pto on for the mower it tries to continue to drive on is this adjustable out or am I seeing a failure coming on?
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Could have some broken plates stacking up on each other or some worped plates. MACK
Would it still pull good if the plates are degrading? It seems to do just fine in gear and working?
Dave (Mid-MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Hemlock, MI Points: 545 |
Possibly caused by wear in linkage between lever and control valve. Try adjusting linkage at control valve to obtain neutral. |
Yes it could pull ok with some broken plates. May not if more break. MACK
allisorange ![]() Silver Level ![]() ![]() Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
We bought a 190 once that had a busted case on the PTO and no oil and it pulled itself up on the trailer because the plates were broke and jammed together.
John Carlson
Post Reply ![]() |
