Hydraulic Project
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Project
    Posted: 18 May 2011 at 6:51pm
Why - early AC thru most of D series the hydraulics were low volume and wouldn't lift a wagon w a big cylinder. Charlyn had a tank pto unit that would do the deed but is a hassle to get on and off and you need the adapter plate for different tractors. I had one on one of my tractors but didn't want to tie it up for just that. Soooo - I just made a angle iron frame for the tank, a 20 inch pto shaft and bolted it to a Cat 1 drawbar. Now I can change it from one tractor to another in 5 minutes if they have 3 pt. I also have the 3pt SC set up so now I can put it on a dozen tractors easy by pulling 3 pins and a quick connect pto shaft. These tanks have both up - gravity down and  two way ports for other cylinders.
The pto shaft is a little tricky - you need female on both ends and a male stub on the tank. I also bolted the lovejoy connection together to keep it all tight. Used all stuff in the project pile - cheap, easy on off and works good.
Have not made myself do pictures yet but can email some if interested.
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 7:34pm
Works but as many PTO are 540 , to get the right combination pump speed and volune - pressure it will take a little figuring .
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 8:47pm
Coke - These tanks are 540 and will operate across the throttle range - just faster lift at higher RPM. High volume - low pressure. Unless I am missing something - it is just a mechanical hook up.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 9:03pm
I've got one of those Char-Lynn PTO pumps, I'd like to see a picture of how yours is set up. Sounds like a neat idea. I bought mine to run a Shaver post driver, but haven't gotten it mounted yet.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 9:22pm
We've got Char-Lynns on several WDs that we have a sprocket on the PTO shaft (under the belly of the tractor), and a chain to the pump that we have mounted on the frame. They work real well to run hydraulic augers on grain wagons, etc.
