D17 oil filter bracket...
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: D17 oil filter bracket...
    Posted: 18 May 2011 at 2:18pm
Hey All!   My D17 Series 1's oil filter bracket is weepin' a little oil, right between the bracket and the block.
Is there anything special about the gasket, or how that fits together?  Is the control orfice in the bracket (putting gasket under high pressure) or in the block (putting it under low)?
Is this a common situation?
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 2:20pm
I'm interested in finding out more about this because ours leaks too.  We replaced the gasket and it still is leaking.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 4:20pm
Clamp the base in a vise where the filter seal touches and use a good flat file to make the base flat against the block. Use good goo on both side of the gasket. Low/no  pressure from the base to the block.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 4:32pm
As the Dr said I have never seen one that wasn't warped and the fix is to file it flat. For the hand challanged lay a full sized sheet of about 220 grit paper on something flat and make circle motions with the base until your cutting all the way across.  Whatever material you use ifor a gasket it should not be thick. I use 1/16 rubber impregnated cork and no goop myself and snug on the bolts is all it takes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 6:26pm
That's a pretty common problem Dave. Sometime in the last year or so, somebody posted a picture of their fix for this. I believe they filled the hollow area on the back side with an epoxy material and then filed it flat. It stiffens the bracket up some. I had a heck of a time with the CA. The block isn't machined on the CA, just plain casting and evidently not real flat.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 6:56pm
If the D17 is similar, here was my fix on for my B oil filter base. I faced the filter base with a mill file, cut a steel plate to match the filter base, cleaned the filter base recess, filled with JB weld, bolted together to dry, smoothed the edges with a mill file, painted and installed. You have a great gasket surface, and it won't drip a drop.
The base as it came from the factory with the recess in the back, and little gasket surface was not AC's best idea.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 7:33pm
That's what I was thinking of Larry. Sorry I didn't remember all the details but it sure looks like it would be superior to the original casting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 11:27pm
Ahhh... yeah, that IS kinda hokey.
Well, I'll substitute the mill-file for a Bridgeport, but I can fill the cavity and cap it with a steel plate.  I take it the same or similar part was used on the B/C and WC/WD engine as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 7:21am
Yep, same part.
