3 point hitch
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Topic: 3 point hitch
    Posted: 17 May 2011 at 6:51pm
Can someone tell me just what a three point hitch is good for! I get mad putting my 7'  three point hitch mower on or off the tractor, I back up to it and them need to move over one way or the other two or three times before its lined up right and I can hook or unhook a snap coupler implement and not get off the tractor, so just what in the heck is so good about the danged old three point hitch? lmao
I think I have removed all the bad words too. lol
Don
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 7:15pm
well, if you have a 3pt, you can hitch up to ANY 3pt tool with the same catagory......
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 8:56pm
There is a big difference between aftermarket 3 pt hitches and the modern factory ones.  The ones with lift arms that can be stretched out make hooking a lot easier.  I have never been able to hook up to my SC blade without getting off and yanking the blade around.  And after a few times putting the hitch on and off my WD switching from pull type to SC there is no comparison.  The SC was supirior in it's time and the modern 3 point is supirior now.
AaronSEIA
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 9:02pm
The 3ph may not be the best, but is univresally used, that is its advantage.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 9:20pm
there is a lotmore three point equipment avaliable than Snap Coupler stuff. they don't make it any more. Very few tractors out here have three point either. most every thing is draw bar pulled. even with a draw barr they don't disconnect the equipment till the end of the season. you don't just wiggle a 110' wide harrow to get it connected.
Phil (WY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil (WY) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 9:20pm
I wouldn't use a 3 pt. hitch if someone gave me the best made at no cost!!  I think it is a sub-standard hitch.  Nothing beats the snap-coupler hitch..  Just my 2cents worth,  Phil
This page was generated in 0.254 seconds.
