Suprise '34 WC
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: Suprise '34 WC
    Posted: 15 May 2011 at 5:38pm
Though it was time to treat the '34 (#629) to an oil change. Warmed it up well mowing lawn, drained the oil and, when I went to change the oil filter I found no pipe in the filter base!
Is there any reason I can't make one out of 1/4" OD X 4.5" pipe? Is the ID diameter critical?
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 6:10pm
You can make one. But it would be easy to find a replacement from a junked tractor too.
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 6:18pm
Did you make sure it's not stuck in the filter?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 6:23pm
  do not push it to far --no oil pressure will happen
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 9:08pm
 We stock  new  oil tubes  .   Tony
