1934 Model E
AL35U View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AL35U Quote  Post ReplyReply Direct Link To This Post Topic: 1934 Model E
    Posted: 15 May 2011 at 1:33am
Working on getting a 1934 E running again.  Changed the head gaskets and got it back into one piece.  Having a little trouble finding much information on this particular model.  Specifically we're not sure how much oil to put in it, can't find a serial number and we're not getting compression when cranking it.  It's sat for the last 7 years, but always ran great until one of the head gaskets blew.  Any thoughts or info would be greatly appreciated.  Thanks!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 7:42am
IF ?? you had it running before removing heads ,DID you adjust the valves ? after putting  head gaskets in.
Would be a lot easyer to help you if  talking to you.
Did it sit 7 years after head gaskets started leaking ??
Edited by Fred in Pa - 15 May 2011 at 7:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AL35U Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 10:10am
Yes it sat after the head gaskets leaked but all fluid except the gas was drained before it was put away. I didn't adjust the valves because I wasn't quite sure how to and one of them is sticking but I was hoping after getting it started that it would break loose.
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 3:10am
Pull the heads off again and do a proper valve job! When you replace the heads make sure that the valves have 12 thou' clearance when hot and after tightening down. These engines run beautifully and have real grunt - especially the 5 1/4" bore version. The bore size will be marked on a pad on the left hand side of the block rear of and lower than the oil filter - which bore is yours?
Tricky Dickie
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 2:51pm
You won't be lucky enough to unstick a valve by running the engine... and it really won't wanna start with the valve stuck... if it's an intake valve, you'll have no manifold vacuum, hence, no consistent draw through the carb venturi.  If it's on the exhaust side, you'll have very poor draw.  Give it the valve job, and make sure the valve springs are good... if they're soft, it won't run well at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 1:24am
That's right - I have noticed that these engines are sensitive to valve and spring condition. If the valves are ok, they run perfectly, but if not they are all over the place!
Tricky Dickie
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 6:01am
The valve springs were weak in mine and i found that valve springs from a 200 fit inside of the orginal springs.
I double springed her and she runs great under load but i still need to work on the carb and i need to resleeve her.  just another project in waiting.
The universal answer to all questions is yes, how much do you want to spend?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 10:26am
Serial number should be stamped on the transmission case just in front of the shift lever. Often this area can be quite rusted and the number is sometimes hard to see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 10:29am
There should be two petcocks or plugs on the left side of the lower oil pan. Fill with oil until it just reaches the level of the upper petcock or plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 3:15am
They always seem to run better under load. The trick is getting them to idle smoothly at very low revs. When they will do that, you know that they are pretty much OK!
Tricky Dickie
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 6:29am
Tricky Dickie
That what i was told so thats why i focused on the valve springs. Only after haveing the valves ground and seated and adjusting the clearance. But mine still idles rough the only thing i can come up with is it must have an intake leak that i haven't found, the throtle shaft could be leaking. number one cylinder sleeve is shot. I got a set of good used sleaves from fred but i haven't gotten around to tearing her down. When i do i plan to address the carb and manifold issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 6:38am
This old boy here ,You can count every fire of ech cyc .when you idle it real low. 5 1/4 bore ,with kero set up .
BTW .This old boy is leaving the country this weekend .Just lost intrest in after getting a few other older toys.
Dave 63 has one just 16 miles away ,why have a couple in just a few miles .LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 6:52am
Nice 30-60 Thresherman's Special! I have one the same, but without those massive double rear wheels. Where's it going Fred?
Tricky Dickie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 6:55am
Canada
tractorchuckie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorchuckie Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 4:36pm
sweet. I can't wait to see it at an canadian show this summer. thxchuck
still looking for the holy grail of Allis
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 8:56pm
Chuck and Terri Have a safe trip with Steve's  new toy. Lets hope US Customs doesn't eat you for lunch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 9:17pm
Maybe they will  just keep Chuck and let Terri go .LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 9:22pm
May have to sacrifice Chuck to get the WF to Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote AL35U Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2011 at 10:08pm
I'm glad you posted that pic of your Thresherman's Special.  We're actually trying to figure out if that's what we have. It's got the 5 1/4" bore, but not the kero set up, although it may have been set up that way at one time.  But looking up information in different places is leading us in different directions.  Is it true they only made 70 Thresherman's Special 30-60hps?  (We use our E to pull and run a 1930 Baker Thresher)  I found the serial number, but it's really hard to make out so that doesn't help anything.
This has all been very helpful so far and I want to thank you all for that.  Hopefully starting on the valves tomorrow, but we at least are getting some compression now.  I'm just not sure we're getting it from all four.
Also, I hope to have a few pics of her up pretty soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 3:02am
uploads/1801/lesvos2010_038.jpg
Here is a picture of mine.  It is a kero model and it is stamped "kero 5 1/4" on the engine number pad. As EACH CYLINDER is 2.3 litres (141 cu in), it really takes some pull on the handle to get it over compression, but will almost always start on the second compression and runs like a Swiss watch, from an incredibly slow idle, right up to the max. I am not sure of the exact number of 30-60's made, but it was not many and they are thin on the ground today, particularly here in the UK. The power and torque of these 5 1/4" bore, 563 cu in engines has to be experienced to be believed and mine feels to have noticably more grunt than my 5" bore kero Model A, which itself is no slouch!  I really like these old E series tractors, which in the past have often been underrated and undervalued by collectors - that's changing now, as their real charm and "personality" is becoming recognised.
Tricky Dickie
Edited by Tricky Dickie - 20 May 2011 at 3:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 10:07am
Trickie Dickie! You are definitely developing 'Orange blood' !LOL  (That TC head must be getting close to you by now!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2011 at 5:27am
Hi Phil; good to hear from you! I do seem to be developing a taste for the early Allis heavyweights - they have real character and are serious pieces of kit. The TC head should be arriving at Lyn Jones' yard in Wales late May/early June and I'll be very pleased to get it and complete the rebuilding of the tractor (not sure that we're supposed to acknowledge the existence of Twin City tractors here - do you think that we are at risk of excommunication!!)  Thanks and best regards.
Tricky Dickie
