Whoops, busted planter gear, got one?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Whoops, busted planter gear, got one?
    Posted: 12 May 2011 at 8:45pm
Well, sometimes I don't make the brightest moves. I decided a couple light taps on this
"ear" that drives the seed plates, just might unfreeze the cast iron drive gear. I was wrong.
Live and learn, the hard way.
Anyone have one they would be willing to sell me? Its for a 500 series planter, and its cast iron. Thanks!
Edited by Don(MI) - 12 May 2011 at 8:45pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 9:15pm
Drill and tap it for a bolt and anchor the bolt or stud with loctite.
Gerald J.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 9:28pm
There are some NOS planter parts on ebay right now but not sure if your part is listed.
Wink
I am a Russian Bot
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 11:10pm
Have this NOS.  I think it is the only one they had of this type.  If you want to count the teeth and give me some measurements....I can compare.  # may be 326323.  Thanks...Dale
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 12:55am
one knob should still run the plate. but then again, if it's rusty...i might bind up and break the other knob or the plate!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 9:03pm
Gerald J.
Thanks Gerald, thats just what I did tonight. Drilled and tapped, 1/4-20 hole, and threw red loc tite on it. Hope she holds good, seemed to. If not, I am gonna have a stud bolt throught the gear plate hit the drive gear! I might take a punch tomorrow and dimple it, so it can't unthread downward.
Thanks for the replys! As always, you guys always come through with advice and parts if we need em! Thanks!
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 2:35pm
Or a spot of weld.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:33pm
Might be easier to braze that ear back on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:42pm
If you got a 5/16 shoulder bolt, it would have 1/4 inch threads and you could cut it to the length you want sticking up and the shoulder would bottom out, stopping it from going through any further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 4:58pm
Thanks guys! I got a couple more ideas now if she breaks again, can't wait to try her out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 12:56pm
Don:  I may have found one of those in my scrap pile.  part #345007?  If it is right you are welcome to it.
jhill52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhill52 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 6:21pm
You can borrowone off my planter if you need to Don.
Jerry
