? 4-14 plowing, 4th bottom not going deep enough??
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Topic: ? 4-14 plowing, 4th bottom not going deep enough??
    Posted: 12 May 2011 at 5:47pm
I'm having trouble getting the 4th bottom into the ground, only going about 4-5 inches. This is it just the first pass; do I have to wait for the second pass? Is the snap coupler hitch too long? Do I need to readjust one of the adjustments? If so which ones? landside heel, snap coupler right side, or the center adjustment.  Thanks!!
 Sorry for the post in the classifields.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 6:34pm
Lengthen the center if there's no gauge wheel.
Adjustments, especially tilt, are different the second pass because of the tractor wheel in the furrow.
Gerald J.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 6:34pm
do a second pass before you make any adjustments
