I'm going to look at a 1946 B Saturday
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Topic: I'm going to look at a 1946 B Saturday
    Posted: 12 May 2011 at 6:50am
I have to make a 4+ hour trip to attend my daughter's wedding Friday. On the way back Saturday, I'm going to make a 10-20 mile detour to look at a 1946 A/C B and attachments that are for sale. Here's the list of what he's got:
'46 B with attachments for sale. The tractor is in good condition. It would restore easily. It has a disc, drag, one bottom plow, back blade and broken but fixable bush hog. All the tires are in like new condition. The tractor is a 6 volt push button start. It runs well.
 Any advice on what to look out for & what this package could be worth is appreciated.
Edited by Protrucker - 12 May 2011 at 7:41am
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 11:19am
Look out for loose wheel on the rear axel. Expensive to fix.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 2:31pm
Sounds like a nice package.
Check the front axle pivot to see how worn it is. Gives you some indication of the amount of time on the unit.
Agree on the rear axle, push/pull each rear wheel in and out to see of it has movement.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 3:01pm
Look for excessive play in the steering wheel. Fixable but detracts from value.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 3:12pm
OK, thanks.
Look for loose rear wheels, slop in the front axle pivot & steering wheel. Anything else?
I know there are a lot of variables, but how about a ballpark value for the package?
Does $1500 - $2000 sound reasonable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 4:40pm
For me, yes it is worth it but I like B's.
Charlie
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 9:52am
Just bought 2 B models this past week, a 42 mod running great, and a 46 mod that needs a little engine work, not much, but some, Looking forward to "playing" with these little "fellers"......
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 12:18pm
Sounds like a very good group of equipment along with a running B.  Hope it works out.  I would think if you could get all that for $ 1500 - $ 2000 you have a great buy.
Take good care of my favorate.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 8:54am
Well, I went to see it and it's in pretty nice shape.
The things That I noticed that needs attention are:
• battery box is rusted badly
• steering wheel should be replaced
• exhaust stack is loose
• right rear wheel moves slightly on axle
• starter sounds like it has trouble engaging sometimes
• left brake not working
The good:
• starts (electric & hand crank) and runs good (no smoke)
• nice tin (no dents or bad rust)
• rear tires are almost new
• front tires are very good
• seat is like new
• lot's of attachments:
original single bottom plow
pull behind double disc's
woods 3-pt back blade
single section spring harrow
   brush hog (needs repair)
We agreed on a price of $1750 for everything & I offered a deposit, but my word and a handshake was enough for him. Now, I've got to find a trailer or make arrangements to have it hauled home.
I tried to post pic's, but tinypic.com isn't working for me now. I try to upload a pic & it's security code never shows up for me to type it in to upload. I'll post pic's when I can.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 11:16am
I would pay for it pronto before $1850 comes along. I'm just sayin' better safe than sorry. Does it have a 3pt. conversion? Sounds like you got a great deal.
David Gibson
http://www.darkecountysteam.com
1956 WD45
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 12:12pm
Starter sounds like it has trouble engaging sometimes? Sounds like to me that the ring gear is about shot. might have to break it in half and fix it some day. I passed up a good running C the other day because of this and it was only 900 dollars.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 12:27pm
If the starter ring was  flipped, you will get a grinding noise in the starter until the ring wears down some so it seats properly. My 48 C does this from time to time when I start it.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 1:25pm
I hope this works, here's pic's of the tractor:
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 1:58pm
Looks pretty nice - good tin!  Tires look decent, too.  Looks like you got a pretty good deal.
I like that solenoid - I've been thinking about doing that to my C as the wife has problems starting it with the rod.
cheers,
Creek
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 2:10pm
Nice looking unit Trucker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 3:26pm
Have fun with it
Charlie
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:29pm
Nice find there and you got a pretty good buy on it, enjoy it and post some implement pics too.
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:38pm
I replaced the wheel bearings and seals on my CA about 5 years ago and didn't cost all that much. Would a B be any different for cost?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 9:44pm
His problem with a loose wheel is not a bearing, it is a worn spline on axek and in wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 10:13pm
I don't think it's much of a problem, yet. I pushed & pulled sideways on both rear wheels to check for play. The left one didn't have any noticeable play, and the right wheel only had enough that if I held my finger on the end of the axle & the hub while I pushed & pulled, I could feel just a little bit of movement. After I drove the tractor so it was sitting a little different, I couldn't even feel any play then.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 12:08am
Sounds and looks like a great deal.  Unless you are working it hard, I wouldn't worry about the wheel looseness much.
Allis Express participant
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 10:42am
I'd say ya done good.
Ron(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 2:45pm
I think you did very well. Now hustle over and close the deal before he finds another buyer who will go you a few dollars better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 2:59pm
I just spent most of the day trying to locate a trailer to haul my new purchase home. The tractor is about 123 miles from here. If I could find someone to haul it for me without costing me 1/3 to 1/2 of the cost of a trailer, I'd do that. I'm almost ready to buy a brand new 7000 GVWR trailer for between $2500-$3000, but I really didn't want to spend that kind of money right now. I've got a lot going out already, between the new tractor purchase & the money I've been spending on remodeling the house.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 4:35pm
Go rent one. Rental store or U haul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 4:42pm
I did check into renting a trailer. No one around here (even U-haul) has an equipment trailer to rent. I'm probably going to end up buying one. Then I'll be able to haul the tractor & anything else that I want without the hassle again.
Heh.....with the price of scrap metal right now, I might try picking up scrap vehicles & other scrap metal to help pay for the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 4:49pm
 I know metal is high right now but the price you quoted for a new trailer sound to me a bit high. It could just be the location but I would check craigs list first
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 10:25pm
The price of steel is up, so cost of trailers made out of steel is up too.
I did quite a bit of looking around & pricing on the internet today. The same trailer that I'm looking at getting locally was quoted at $800 more down in Mechanicsburg, PA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 10:36pm
Just a thought. If you mentioned to uhaul that you wanted to haul a tractor they would naturally say they don't have one. I believe there car trailers will work just fine. So you call them and tell them you need to haul a Geo and see what they say unless you really need a trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 10:47pm
An Allis B will fit on a 6' open trailer, but you cannot tell U-Haul that you are hauling a tractor. Manure, large appliances to the dump, furniture... anything but a tractor... I think they even have a clause in the contract about it...
Miles Gray (CO/KS)
