1/4" OD tubing for sediment bowl inlet
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: 1/4" OD tubing for sediment bowl inlet
    Posted: 09 May 2011 at 9:29pm
Should I expect to be able to buy a small length of tubing to use for raising my fuel inlet off the bottom of my CA's tank?  Or can you only buy that size by the roll?  Or would anyone consider dropping an inch long piece in the mail to me for the right price?
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:42pm
My father in law who was a tractor tech for years told me to get some sediment bowl screen and roll it up and stick down in there. Said It would not let the junk on the bottom though and you did not have 3/4 inch of gas left in the bottom of the tank either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:21pm
I had a couple hiccups in my 45one day, of course I had to be 5 miles from home at the time. I drained the tank and pulled the sediment assembly off.The inlet is the perfect size for a 1/4 " NPT tap. I cut a few threads in the top of the base and screwed a short nipple in. Reassembled it and haven't touched it since.
 I do believe a place like TSC or Farm and Fleet has screens a couple inches long that have pipe threads on one end and closed on the other end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:25pm
Murph, Steiners sells a screen already made up for that. Cheap enuff too. HTH Tracy Martin
Edited by Tracy Martin TN - 09 May 2011 at 10:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 7:45am
Thanks guys...  I'm glad there are other options.
Edited by Murph-NC - 10 May 2011 at 7:46am
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 7:51am
we have what you are looking for on our web site, a push in screen for sediment bowl.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 8:57am
I've also done the 1/4" pipe nipple deal, only I used brass ones with several small holes drilled in the sides.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 9:49am
A small tightly wound spring works as a strainer too.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 12:24pm
Before ya'll rush out and get your 1/4" pipe tap and fittings I'm pretty sure the guys mean 1/8"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 1:26pm
Yeah, I was actually thinking they might mean 1/16 NPT... the inlet hole in mine is 1/4", and the tap drill size for 1/16 NPT is 0.246.  Although that size might not have a large enough ID.  I'll make one or the other work if I go that route.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 3:02pm
Glad somebodies awake. I know I didn't drill out the hole on mine, just ran a tap in it.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 5:24pm
What are they listed under, David, I couldn't find them.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 7:29am
Here is the item.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 12:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 2:23pm
Thanks Tucker, Took picture AM and had wife load. Adding new parts and pieces as I find them or have made. NOTE if anyone is looking for a part and it's not on the web site, give me a call as we might have it and just have not had time or forgot to load it. THANKS David 734-320-3470  www.djstractorparts.intuitwebsites.com
