D19D Back on its feet!!
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: D19D Back on its feet!!
    Posted: 09 May 2011 at 6:01am
Hi Guys,
The D19 is moving again under its own power!  This was the tractor that was a diesel had been taken to gas and now I made it back to a diesel.
It took parts from a 230 gas and (2) 262D's to come up with one solid 262D engine.
Thanks to Matt Scott from Jordan and Brian Jasper Co Ia for the pictures and tips they provided me along the way.  Many others helped to via this website...thanks!
How coldblooded are these things?  It seems it blows white smoke until it gets up to operating temperature.  Is that normal?
It starts fairly well...if I hold down the preheater for a minute or so.
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 6:27am
Wow, that was quite a project,  but you did it. Nice tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 6:52am
Hey, that's a familiar site. I made a few laps around the 'block' with mine yesterday. Nothing sounds like that 6cyl Buda does it? Glad I could help.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 8:12am
Brian, I couldn't agree with you more. My D17 D with the 230 budda gas sure sounds mean. I did have a 3" strait pipe on it which made it sound like the big boys.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 12:33pm
Good work! are you going to paint the rest of the tractor someday?  What's a Golddigger Pro? (in the pic behind the D19)
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 4:44pm
The Golddigger Pro is a tiling machine.  Ton of tile going in in southern MN.
As far as painting it, I wasn't going to initially but now I may.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 5:21pm
I know there isn't any farmland left in Champlin, where do you farm? I moved from Howard Lake to Champlin to Coon Rapids and now to Oak Grove.
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 6:20pm
I'm a farm kid living in the city.  I am originally from near Albert Lea....2 miles out of Freeborn, MN.
My neighbors are all wondering what a 60 hp tractor is doing in the neighborhood! Kinda of fun...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 6:33pm
My mom grew up by Albert Lea and have cousins by Glenville still farming. I wouldn't mind having my dad's old series IV 17 sitting in my yard but it got sold when he retired.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 6:51pm
The smoke is not normal though, I have used ours for 40 some odd years and it never "smokes" when cold, also, I never preheat unless its below 40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 7:50pm
All depends on how cold it was. My 262 made smoke like that when I first got it together and it was in the 50's. Didn't smoke like that very long though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:43pm
Good to see you got it runnning. Mine smokes pretty good to until it is warmed up. It will smoke less and start better once the rings start to seat. Glad i could help.  Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 9:05am
Where's the turbocharger, might clear the smoke a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 11:12am
I put an aftermarket turbo on it (Garrett T04).
According to a website, white smoke is from:
Diesel engines have difficulties in cold starting. Cold starting means low temperature intake air that is coming inside the cylinder, low temperature walls, low temperature piston head. All these are making the fuel evaporation difficult. More, the usual way to start a diesel engine is to flooded with fuel.
I
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 6:56pm
Doesn't the D19D engine have a little bit lower compression than the non turbo 17 engine?
