180 hard starting |
Post Reply ![]() |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8209 |
![]() ![]() ![]() ![]() ![]() Posted: 08 May 2011 at 12:52pm |
Just put a new engine in a 180, new rebuilt injector pump, along with injectors ; it runs great but when you first start it , it takes a little bit to get it started ,, it does have the old big starter on it - it has a new 1200 amp battery ; seems to turn over fast just wont start right off the bat ; smokes- but slow starting , I redone a 200 bout 7 years ago and it started on the first round even at 20 degrees ; would the smaller newer starter help you think ?
allis6080 ![]() Silver Level ![]() ![]() Joined: 19 Jan 2011 Location: erie Pa Points: 334 |
sounds like you mite be a degree or two off. i had a 180 do the same thing when i took the the inj. pump off to be rebuilt. can't remember but i think i had to advance it alittle. hope this helps. some one mite know better than me though.
6060 s\n 5016
1947 JD B |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21080 |
If you use the manifold heater for 60 seconds it will start right up, correct???
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 32552 |
My old 180 is far from rebuilt but pulls even and strong with little blowby, it is however a pig to start below 50 degrees needing ether most of the time, above 60 it cranks a little long but usually fires up loaded up. I chalk it up to a roosa master style pump, weak nozzle settings and just low compression.
Yes Dr . if you use the heater it helps a bunch; or use the water heater it helps , the timing is dead on , could advance it a degree i guess
Retard a degree or two for better starting on an AC engine....better yet...advance it and see how much worse it is and then retard it.
Will this affect the engine performance at all ? I,m doing this for somone and dont want to pay for it !!!!
thanks dr. i couldnt remember which way to go its been a few years!
6060 s\n 5016
1947 JD B |
Make it start better and then see whay you think...a 180 is to be timed at 22 degrees.
OK , I,ll try that !!!! Thanks again Dr A !!!!!
Post Reply ![]() |
