hi tran oil
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Topic: hi tran oil
    Posted: 06 May 2011 at 9:27pm
i know this subject has been thrown around before,but can the wd 45 gas and diesel use it in the differential,transmission and the hydraulic pump?what effect would it have on the 50 year old plus seals.dont know what the load bearing quality on the older gears would be also is the newer fluids synthetic or petroluem based or possibly ester based...thx all...
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:30pm
It would be good for hydraulic but NOT transmission which takes gear oil 80-90 I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:44pm
Use it in hyd,trans and rear end. Much better than the 75 year old design of 80W. No reason to use 80W with today hyd wet brake oils.  MACK
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 11:52pm
I've often wondered about using hy-tran in autos to semis in the differentials and manual transmissions.Currently using 50wt in the Fuller 13spd(as recommended) I'd almost bet the 440 with a Fuller used 820 in trans...maybe not?
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 1:39am
I put hy-tran in my WD in everything except the final drives, really shifts and runs smooth. I put 85-140 gear oil in the final drives, the thicker the oil the quieter they will be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 6:52am
I've used it in both D-14s for the past 8-9 years.Sure makes it easy to 'top up'.Same stuff in every hole!Cept engine and finals,of course.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 7:01am
I had a Honda CRV all wheel drive and at about 40k the viscous coupling in the dif started making noise when turning sharp. supose to use some special fluid (very expensive) I put UHTF low temp in it and the noise went away, drove another 50k and sold it.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 7:15am
AC Lube Charts dated 1971 show PF821 in Trans/Diff/Hyd Sys, only compartment using gear lube is final drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 7:39am
If it can be used in the tractors of today, running from 100hp to 3 or 4 hundred, why would it hurt in a 50 year old tractor with 30-50 hp?
 I've had it in the tranny of my45 since I replaced 3rd gear right after I bought the tractor in 1980.
Edited by CTuckerNWIL - 07 May 2011 at 7:41am
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 9:23am
Sorry if this is a dumb question, but by 'hi tran oil', do you mean something like Permatran 821XL?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 10:05am
Yes, many refer to it as hytran or transdraulic fluid because it is used in hydraulic systems and transmissions. The 821 is a spec that Allis recommended for their later tractors.
Farmer Roy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Roy Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 6:38pm
Hi Tran is what IH called there hyd oil
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 7:05pm
My dad kinda was thinking something similar. We had work done on our 1950 WD and the dealership put hytrans in the rear. My dad thought that after running the thick stuff all the tractors life maybe the thinner hytrans would cause the old seals to leak!! Considering the tractor gets maybe 20 hours of use a year It wouldnt have bothered me but the ol man still the boss!! Ryan
This page was generated in 0.158 seconds.
