Allis G hydraulic pump
Charles (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Topic: Allis G hydraulic pump
    Posted: 06 May 2011 at 5:57pm
I am trying to find a bearing either new or used or a picture of one for a Allis G hydraulic pump.  The bearing number is 800735 and is item #4 in the parts diagram.  Any help would be appreciated.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 6:08pm
If you have the old one, read the part number off the bearing and go to a bearing distributor. Most of Allis Chalmers bearings were standard issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 6:28pm
Call Sandy Lake Implement 1-888-252-0656
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 7:15pm
Unfortunately this bearing was a Allis only bearing.  The old bearing is not the correct bearing.  Several of the bearing in the allis G hydraulic pump were Allis only bearings.  Local bearing dealer cannot cross it over.  Hopefully SandyLake can help tomorrow.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 7:20pm
  we have crossover to the bearings  will check
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 8:22pm
Take A caliper and measure i.d. and o.d. and width then check style . You can look it up on computer. I bought four bearings for trans mission for finish mower for 36 dollars including freight. Shop around .Most come from China anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 9:23pm
Charles, I feel your pain. Been there done that. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 4:59pm
  it is a ndh bearing looked this morm all info. at shop  puter at home   1-800-254-3116
    will check availability   wth a snap ring
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 10:08am
I have an Allis-Chalmers Part Number Bearing Exchange List in the front of my A/C Master Parts List:
AC Part  Number - 800735
New Departure - 43303 or 43308  print is not good but I'm pretty sure it's 43303
Best regards,
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 8:18pm
  we have a used one or can get a new one  your choice  a phone number would help for a quicker response  1-800-254-3116 for a reply  over nite delivery if wanted  we have crossover for all A-C bearings
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 9:05am
Scott, The real question is ... Do you have the crossover for the bearing on the other end of the shaft? Number 800736. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 9:34am
Well...
The Bad News:
The first problem is the lists are Bass-akwards.  They are listed in groups - the groups are the individual bearing manufacturers.  Then, under the manufacturer's group, they list the part in numerical order BY THE MANUFACTURER'S NUMBER.  As a result, I have to scan through several pages of poor print with dimming eyes blah, blah, blah...
The Good News:
I haven't gone through the whole list but I have found one!
Rollway W-919
Allis-Chalmers 800736
Best regards,
Scott
This page was generated in 0.281 seconds.
