Allis B Lost Its Oil Pressure
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Lost Its Oil Pressure
    Posted: 05 May 2011 at 5:50pm
First time it ever happened for me just setting over the winter. I have tried to explain how easy it is to prime the pump but it never seems to get across. I happend to have my camera with me so I took some pictures.
I disconnected the oil line to the head, pushed a hose over the fitting, ran the other end of the hose up thru the hood besice the oil filler, took a pump oil can and filled the the hose, let it set for less than five minutes, put the hose in a bucket and started the engine. As soon as I had a good flow which was right away, I shut the engine off and put the fitting back together.
The dirty looking oil is the liquid color stuff washing out of the hose.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 6:03pm
If a picture's worth a thousand words, those three pics saved you a lot of typing. Such a simple thing to check. Thanks for the post.
are genuine." - Mark Twain
