D17 Rearend Pinion bearing
Cooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cooter Quote  Post ReplyReply Direct Link To This Post Topic: D17 Rearend Pinion bearing
    Posted: 04 May 2011 at 10:16pm
How do i take apart the rearend pinion bearing on my 1958 D17? Do I need to take off the tires and work my way in on both sides on the rearend or is there another way?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 6:24am
In a nutshell.....YES.  You don't necessarily have to remove the wheels from the axles, but the axle housing must come out each side, and it would probably be easier to have the big bulky heavy tires and rims off, for alignment purposes.
Still in use:
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 6:40am
Are you talking about large bearing at outboard end of Trans pinion shaft? If so, you have lots to remove before that is exposed. Split tractor, remove transmission gears/shafts, finals off, etc, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 2:46pm
I was thinking the same thing Chris, but the more I look at the manual and the parts book, I think a guy could remover the axels, the differential, and pull the shaft out the back, while a guy lifts out the gears from above one by one, since the top shaft in the trans is not solid, it is two pieces, the rear shaft sits in a pilot bearing in the front shaft.  I am not sure this approach would work, but it saves spliting the forward portion of the tractor, rather than opening up the front AND back halfs.  The only thing I can see that may prohibit this, is the rear pinion bearing lock ring, and nut, possible the gear bushing lock pins.
Edited by Orange Blood - 05 May 2011 at 2:47pm
Still in use:
