allis chalmers 8550 for parts
humphreysfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers 8550 for parts
    Posted: 04 May 2011 at 8:17pm
hi i have a 1980 allis chalmers 8550 263 hp for parts. The tube came off the bottom of the oil pump and lost oil pressure as soon as the engine oil light came on i shut the engine off. We did pull the oil pan off an i did notice that one of the crank bearings were scored so i didnt go any further tearing it apart.If you are interested in parts you can contact me at 540 295 5055 my name is brandon and the tractor is located in fredericksburg virginia.my email is humphreysbrandon@gmail.com i can send pictures if needed. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:14am
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:20am
Saw a You Tube video the other night where someone put in a Detroit in one of these and it ran like a scalded cat.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 2:43pm
Wesley, you need this!
Charlie
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 2:47pm
If anyone is looking for an engine for this beast, I have a 450 hp A-C 25000 MKII engine with 1079 hrs from a generator that will bolt in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 8:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 8:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:11pm
i recently bought a used georator pump still it the box it runs the hydralic remotes and 3 point hitch i didnt get a chance to put it on but we also put shift cables for the high and low and the gear range and rebuilt the turn cylinders and the 3 point hitch cylinders. The tires on the machine look to me like they are about half tread but i measured the lugs they got about 3/4 tread.We just ran it in october to work up 80 acres the transmission shifted good and the two speed on the floor worked. The bolt come out of the oil releaf valve and lost oil pressure and spinned the crank bearings we only pulled the cap off of one we figured the rest are probably in the same shape.We never used the pto the shaft is twisted on it. If your interested just shoot me a offer i know most of yall that are interested shipping is a big part in moving this thing i can easliy load it for you thanks.
Edited by humphreysfarm - 07 May 2011 at 8:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 10:13am
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 5:29pm
I see your problem, it has nothing to do with the oil pump, rods or mains, it's that damn Deere key you have in the ignition.  Replace that, and I be she runs another 15 years without a wrench to her.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 8:57pm
For a update i have a sale pending on the engine everything from the fan to the clutch front axles and wheels and tires and the 3 point hitch quick attach.
Im looking to sell the (these prices do not include shipping)
turn cylinders for $350 a piece
 the georator pump that runs the output hydraulics and 3 point hitch for $300
the cab make offer if interested
the transmission $1000
the back set of wheels and tires (4)$1200
rear end make offer
the drive shaft that runs the rear end $200
radiator $300
the passenger side panel is bent it fell off and got ran over but i do still have itcould probably be staightened i will put up a picture soon. i would like to get rid of the left and right side together $150
the front grill $100
the top panel that wraps around the exhaust $100
Post Options Post Options   Thanks (0) Thanks(0)   Quote humphreysfarm Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 5:28am
the grill rear fenders the hood the turn cylinders the front lights with bracket under the grill and the drawal bar hitch are in a pending sale.
still looking to sell
the transmission
cab
radiator
rear wheels and tires
rear end
3 point hitch arms
3 point hitch top link
georator pump
