M Track-ter pull
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Topic: M Track-ter pull
    Posted: 04 May 2011 at 8:07am
I just had to see what the little M would do with the dead weight. No one could come close in 6500 class. I guess I might have to keep it and I might even put on a little more fresh paint . Scott
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:30am
Nice M!
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:37am
Next thing you know, you'll see track layers coming out of the woodwork to pull a stone boat. Then we would all have to make sure we read the fliers right to tell if we are going to a tractor pull or a Track-ter pull.  LOL
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 2:36pm
   What pecentage did she pull ? Surely you weren't in a class with tired tractors ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:14pm
Randy, We were pulling for fun, I think there were 11 concrete weights 500 lb each when the 40 Cockshutt with 20 " drawbar couldnt pull any more. they added 1 more weight and the M pulled it also. The m's drawbar was 14" . I think it could have went one more round but i felt as if that was enough. No mater how you figure the 37 crawler can still pull its own weight. What percentage did they pull at Nebraska? PS , We were all tired !!! HA HA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:42pm
   I bet she would have pulled at least another 1000 lbs ! We do a dead weight pull here to and its just a fun pull, but we do figure the percentages just for braggin' rights !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:49pm
I know one thing for sure , my HD5G can not pull out a fully-loaded concrete truck with 12 yards in the drum when burried to the point it can not move under it's own power with 6 wheel drive.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:50pm
Test no, 239 in low gear M,s can pull 5009 lbs or 73% of its own weight at 2.05 mph and putting out 23.8 horse power.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 4:00pm
This little M must just be broke in and in the prime of its life!! like me. Scott
