transaxle lube Model B
Scott in MA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott in MA Quote  Post ReplyReply Direct Link To This Post Topic: transaxle lube Model B
    Posted: 02 May 2011 at 10:47am
Hi:
My Model B vintage owner's manual specifies 20 weight oil for the transmission/axle. I can't find this weight anywhere. Is there a modern equivalent that will work. Also - here's the dumb question. Do I need the PTO engaged for the hydraulics to work? They don't work otherwise and I wonder if this is by design or something is wrong with my tractor.
The reason I ask is this - I have a Woods belly mower. If the PTO is engaged and the mower is spinning, the long belt will come off if I try to raise the mower. It would be nice if I could raise the mower without losing the belt. The belt is properly adjusted but I can't raise the mower ever unless I want to constantly be on my hand and knees on the wet grass.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:57am
I can raise the mower on my B without the belt coming off, maybe your belt could be a wee bit tighter.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:13am
 you can use any motor oil  [10/30 -15/40-or uinv. trans oil] DO NOT USE GEAR LUBE!    I have a woods 306 on my 39 B  the belt does not come off when rasing it . when I did have that problem  .a new belt solved it  yes the PTO has to be in gear thats what runs the pump . if you dont have a owners manual for the mower i will be glad to copy mine send a p. m. with adrs.
