Would you belive this started as a brake job?
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Topic: Would you belive this started as a brake job?
    Posted: 01 May 2011 at 11:45pm
Sad but true!  I was looking forward to a nice simple brake job on the old WD45.  Believe it or not she had the original brakes yet.  I figured this out when I saw the brake pins did not have any paint off of them and were really rusted in there(big surprise).  It all started when I pulled the covers off and say the axle seals were leaking some and there was oil in around the brake area. While taking off the left wheel I found I had a final drive bearing going out as well as a leaking seal, the other final drive axle is leaking some too but not as bad as the first, but will be replaced while I am there.  When I pulled the diff carrier off on the left side to remove the seal I was brought to the attention that the carrier bearings were pitted and needing replacement as well!  While the wheels are off I am also freeing up and repairing the wheel eccentrics.  Where does it stop! lol  Last year I overhauled the engine (first time as well), rebuilt the hydraulic pump and replaced a few pto gears, and replaced many gaskets and seals.   I'm hoping after this that the old 45 will be good for another 50+ years! lol Had to share.
Jim
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 12:07am
In a word, YES!
Allis Express participant
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 6:47am
Looks like one handy stand you got under her!
Greg Kroeker
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 6:54am
It would still be a brake job but your the kind that wants to get her done right.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:04am
Good job Jim!!! It will be a great feeling to know what you have after its all fixed.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:22am
Brakes? who needs brakes anyways??? Not sure but I think the tractor is just making excuses to sit inside the shop??
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:36am
I know it takes a while, and some money, but if you are like me, you will feel readly glad you didn, when it's done, and will know it was done right.  Until that pesky 1st drip appears :-O
Still in use:
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 8:10am
My D14 is waiting for the same treatment.  In its case, I won't be able to quit 'til I get to the Power Director :-/
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:49am
What is the thing mounted under the generator on the  B?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:56am
well...while yer in there...just as well!! been there before!!!
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:00am
Jim, you've got some really nice looking original tractors there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:57am
My D17D started out as a simple head gasket. So far it's turned into a complete rehab from the flywheel forward. It has noisy bearings in the rear, so something tells me I'll be tearing the rear end apart too....
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 12:06pm
Mine started as an exploded Governor, found broken teeth on the timing gear, now I have the entire engine apart and need a new crankshaft and pistons... but as everyone has said, once it's back together, it will last for another 70 years...
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:18am
The the thing under the generator is actually a home made generator bracket.  That B is a 1940 and did not have the bolts in the block for the generator mount.  I am in the slow process of converting it back to a hand start B.  I am planning to have it match up to my 1940 40 combine.
Jim
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:08am
That is what you call having fun.....course more fun is using it after you finish the job.
This page was generated in 0.719 seconds.
