Correct D-Series long decal
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Correct D-Series long decal
    Posted: 01 May 2011 at 8:34am
Which decals are the actual correct ones? I have seen the D-17/D-15 long decals that have the aluminum and black trim around the letters and the outsides of the decals. Then I have seen them with no aluminum. Just black letters and black trim around the decals? Which one is right?
"Better By Design"
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:40am
The aluminum I think are the early seies
1965 D17 Series IV
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:09am
They came both ways depending on the year.  I would guess that they made the change somewhere in late 1964 or 1965 prior to changing the font of the ALLIS-CHALMERS altogether on the later D-series models.  My Grandpa's Series III D-17 had the box around the ALLIS-CHALMERS decal, and my Uncle David's Series IV D-17 did not.  I don't know the serial number or year of my Uncle David's D-17.
Grandpa's Series III D-17.
Uncle David's Series IV D-17 without the box around the ALLIS-CHALMERS.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:16am
Here's a color photo of Uncle David's D-17 that helps see it a little better.  His D-17 still has the five bolt rims.
Matt Folkers
FOLKERS RESTORATION
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:17am
The long decals are for series III & IV D17 only, the D19 had similar decals but with the silver. My series IV D17 with original decals is only the creme & black. I think some companies make all their decals like the D19.
Edited by Dave in il - 01 May 2011 at 9:18am
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 10:09am
I think the series III D17's had the black/metallic box around the Allis-Chalmers and the series IV did not. Don't know about the D15's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 10:28am
Series IV D-17's came both ways page 89 in Norm Swimford's book shows both decal variations.  I'm not real sure on the D-15 but I would imagine they followed the same decal pattern.  Like I said I'm betting they changed the style somewhere in late 1964 or 1965 but I doubt anyone knows the exact date for sure.
Matt Folkers
FOLKERS RESTORATION
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 10:35am
 compare apples to apples  metal names were used in early 60,s   also  norm swinfords book tells  with serial #,s when each was used
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 10:52am
Nobody was even asking about metal name plates?  Austin was asking about decal varations in the later D-series concerning some of the lettering on the decals and the trim, not the metal name plates.  The varations that Austin is asking about in not noted in Norm Swimfords book from what I have seen.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 1:04pm
Yea...I am not asking about name plates. I know the difference in that.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 1:11pm
I have a Series II D-15 with the long decal without the silver trim. I am not sure of teh Serial Number though.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 12:59am
All D19s I've seen have the silver on their decals. Since the D19 was built from 61 to 63, I would speculate the series IV D17 changed in 64 to match the new 190 graphics.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 5:27am
I have a neighbour with a D-15 II serial 15000 (63) with silver around the name on the long decal that is the same as the D-19 and looks like its made to look like the metal plate.
I have a D-15 II serial 23xxx (67) and a D-17 IV  (66) that does not have the silver around the name.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:43am
   The D19 was built from 1961 - 1964.
http://www.rumelyallis.com
