B hyd pump questions
hermin's dad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hermin's dad Quote  Post ReplyReply Direct Link To This Post Topic: B hyd pump questions
    Posted: 25 Apr 2011 at 4:22pm
where is resevoir for hyd on b, controls? have tractor with delete plate wondering about all this. Anyone have one for sale resonable?
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:26pm
The reservoir is the transmission housing, so you have one. You need the pump ans connections. Call Sandy Lake Implement. They have rebuilt pumps 1-888-252-0656
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:29pm
Make sure you change tranny fluid to Universal Hyd/ Transmission fluid. It is what is needed for good operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hermin's dad Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 5:45pm
what about controls are they located on the pump,are there tubes going down into the trans housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hermin's dad Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 11:57pm
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 6:23am
The pump runs off the PTO shaft so your PTO has to be engaged for it to work. The only other control is the valve which is on the pump. There is one pick up tube that hangs off the pump.
Edited by CTuckerNWIL - 28 Apr 2011 at 6:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hermin's dad Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 4:28pm
Purchased pump off ebay. How long is pickup tube for pump?also are gaskets avail for pump and pto if pto has to be removed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 5:19pm
The pick up tube is not very long. It comes out of the pump and turns down 90 degrees. probably not more than a 1/2 inch below the pump. Gaskets can be made very easily. Lay gasket material over the side of the pump and tap around the edges and holes with the ball end of a ball peen hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 5:27pm
If you have the delete plat, all you should have to do is remove it and bolt the pump on. Hook up lines to your cylinders, pour in some fluid and you're ready. You might want to stick the pickup tube in some oil and manually pump it to prime it before assembly.
This page was generated in 0.073 seconds.
