WD45 Knock
dm22p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dm22p Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Knock
    Posted: 24 Apr 2011 at 12:22pm
My WD45 had an engine knock, so I pulled the engine and disassembled it. The #4 rod bearings were badly worn. I took some measurements and the first 3 rod journals measured about 2.340. The low spot on the #4 however, measured 2.331. I'm assuming the crank has already been ground .030 undersize. If that's the case, will having the crank ground .040 undersize correct the problem? If so, are .040 undersize rod bearings available for the G226 engine? Thanks
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 12:58pm
DM  !    If your  crank  will grind  to  .040   we show Rod & main bearingsto  .040  but  i like to call  my supplier and confirm  in stock before  quoting. Tony  1-877-602-3994
