three point conversion ?
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: three point conversion ?
    Posted: 24 Apr 2011 at 10:13am
Got a cross three point conversion for my wd45...
Question on the top link bracket....its nothing more than a u-shape with a couple bolt holes.  One set of holes for the arm, the other to keep the bracket on the tractor lift shaft..
But what is to keep this bracket from sliding all over the tractor lift shaft???
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:15am
nuthin!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:18am
Like Bob said... it's just clamped on.  Really, since the top link can swing every-which-way, there's not enough side-load to make it take a walk.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 4:55pm
I simply put two muffler clamps on either side of my homemade top lnk bracket to keep it centered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 5:18pm
in reality the rock shaft rotates, but the bracket dont. It always points directly at the top link pin on the implement. Straight pull.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 5:23pm
I had to put a muffle clamp on each side of the bracket to keep it from sliding back and forth.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 6:07pm
Mine is like Brian and Dave's. I have a muffler clamp on each side.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 11:19pm
Sounds like its not much to worry about...
Thanks Guys..
Tom
