D17 Power-Director Hand Lever Problem
tcorbett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tcorbett Quote  Post ReplyReply Direct Link To This Post Topic: D17 Power-Director Hand Lever Problem
    Posted: 18 Apr 2011 at 6:29pm
I inherited a D17 series II from my Father.  When I was young working on the tractor the Power-Director hand lever would always pop out of high range.  The Low range always stayed in place.  My dad never thought is was worth fixing. I would like to fix this for safety reasons, is there an adjustment to keep the high range locked into position besides my dad's bungee cord?
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:31pm
Sounds like the rollers are worn, as well as some of the other parts.  Sounds like it needs to be taken apart and rebuilt.  At least you will know what you have then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:58pm
First thing to do is remove the high side "stop bolt"....takes two 9/16" wrenches.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:41pm
  the longer you wait --the more expensive it is too fix  my 2 cents
  have some one to check that knows what they are doing  an old a-c mechanic
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 8:02pm
It sounds like the ramps need reground.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 10:18pm
That would be my first plan of attack....it that doesn't do it I use the lever as a footrest....
ALLIS EXPRESS!
This year:
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 5:15am
The first thing I would do is make sure the setscrew in the handle is tight. You need to hold the square head and loosen the nut. Then tighten the screw. The screw is tapered and fits in a tapered hole. That may have been the problem all along.JP
This page was generated in 0.127 seconds.
