Plow set up, what am I doing wrong?
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Topic: Plow set up, what am I doing wrong?
    Posted: 18 Apr 2011 at 12:10pm
D17 III with an aftermarket 3 pt hitch.
This was the first time I was plowing with the tractor.  There is a metal plate about the size of a deck of cards that holds down the tow bar to part of the 3 pt hitch.
The forces from plowing has pulled apart the two bolts that hold the metal plate over the tow bar.
Any idea what I'm doing wrong, and how to do it properly?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:29pm
You need to take the drawbar off when plowing. However it looks like your using a draw bar mounted threepoint. in this case you need to shorten the drawbar. it should have two bolts that hold the two parts together. I would not use it in your current configuration. you stand a good change of  breaking your housing where the drawbar bail attaches. your best action would be get a correct snap coupler plow. or a snap coupler adapter.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:32pm
   You need to shorten the drawbar. (part that has hitch ball on it)
Edited by Rfdeere - 18 Apr 2011 at 12:33pm
http://www.rumelyallis.com
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:42pm
On that style of 3 pt that bolts to drawbar it puts alot of stress on the drawbar and the mount you are talking about. Only thing holding drawbar is the eye in the front and those two bolts and plate on support. Good luck I have same 3pt and it works Ok for most things but other things its not the best
Phil
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:42pm
Get a SC plow,that 3 point prolly won't work with a 3 point plow.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:45pm
I agree with Dave, there are just too many dynamic forces involved to make that hitch work properly. The alternative if you are intent on using that plow is to take the drawbar and bail off of the tractor and fabricate a proper mount for the forward attaching points of the lower lift arms. That bracket should be at least 1/2 inch steel.
The down side of all this is that neither the set up that you have or a fabricated bracket will give you draft control, very important to do a proper job of plowing.
So, you are left with a snap coupler to three point adapter or going to a snap coupler plow. I'd like to give you a more palatable answer, but those are your choices.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:45pm
Most D-17's that I have seen have a 1 piece drawbar that you can not shorten. Wd's and Wd45's are the ones with a 2 piece drawbar that you can change the length on.
that style of 3 point hitch are not very good for a mounted plow. too much lateral movement. they are intended for light duty use, blade or a mower. What happens if you tighten up the bolts?
tractorbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:45pm
It appears that you are attaching a Cat.1 plow to a tractor 3 pt. hitch designed for a Cat. 2 . The hitch is acting as sway blocks, but the width is too wide for Cat. 1 implements. Things will continue to break if you don't widen the connection points on each attachment .       Bob
Nate (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nate (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:47pm
Just take the drawbar off while you plow or move it off to the side so it clears.  My .02
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:48pm
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:55pm
I am with Dakota Dave,  When it comes to trying to plow with a 3 point adapter there is no best way for a number of reasons, sway and positions control being two biggies. Sway is what is bending your hitch and the bad top link geometery (also common with adapters) isnt helping matters either.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 12:55pm
I tried to use a kaverland plow that was 3 point on my D17 with a adapter hitch like yours. It didn't work. sold that plow and got a nice snap coupler one works great. there was some thing about the the way it lifted and set into the ground that i couldn't get it to work.
Allis orange blooded by family. Allis Diehard by choice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 1:06pm
Is that plow a home converted from snap coupler to 3pt? I agree with the others that a light duty aftermarket 3pt isn't going to work. I wish I had pics of the 3pt I sold off my D17D to another forum member. There is no comparrison to yours. The one I sold was built heavy enough that you could pick the tractor up with it and the traction booster was still fuctional.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 5:33pm
Sell the plow and sell the 3 pt adaptor and find a 3-16 or 4-14 snap couple plow and a set of lift latches. You won't believe how nice the proper set-up works when you have draft control with your traction booster.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:54pm
Since I'm guessing you have other 3pt implements you aren't going to want to get rid of your 3pt conversion. I have the same conversion on one of my D17s and it works well for everything else, but for plowing go with either a snap coupler OR a pull type plow. I have a pull type IH model 60 3-16s with hydraulic lift , and a 4-14s snap coupler either works great.
Phil (WY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil (WY) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:20pm
Get rid of the 3-point hitch to start with.  I think it is the most worthless hitch ever built and get a snap-coupler plow and you will be amazed at the difference.  Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:13pm
I'll try pics first one is a 3point keverland .didn't work Nect is a nice snap coupler plow.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:24pm
I have a Farmall H with a nice heavy built Saginaw 3pt on it. I tried once to plow with a 3pt dearborn. Didn't work worth a crap and bent stuff. Basically use the original stuff set up as intended and it will work for you.
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:28pm
Heres the 3 point that i made for my D17, and i know the traction booster does not work with it but it is good and strong.
Go orange or Go home!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 5:58am
Yep, save yorself all the head aches and find a nice snap coupler plow. Look for a 73 or 83 model with 387 bottoms.
Wink
I am a Russian Bot
This page was generated in 0.186 seconds.
