d17 hyd problem
otis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote otis Quote  Post ReplyReply Direct Link To This Post Topic: d17 hyd problem
    Posted: 16 Apr 2011 at 9:34am
why does my series iv keep busting hoses and lines in hyd system.when i use remote hyd,pump seems to pump against its self,then blow a hose or steel line.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 10:09am
My 220 has a pressure relief for setting hyd pressure.I assume your ser 4 is similar since it has the external gear pump.If set too high....you can split the pump housing.The relief is up at the valve stack on my 220.Better get a guage and see what's going on before your looking for a pump.
Edited by Steve M C/IL - 16 Apr 2011 at 10:10am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 10:42am
sounds like the relief valve stuck, switch the draft control relief valve with the main relief (thats the two identical valves that have the round acorn nut on the end - one faces front and the other faces the rear - unscrew the entire valve and swap - valves located on each end of the valve stack behind your right elbow under the flat sheet metal - accesable without removing any sheet metal.)  Then test to see if you still have the pump loading. If not take the offending valve apart on a clean area and surface and replace the oring and find the stuck parts - this is a double stage relief valve designed to dump large volumes without damaging systems.  The traction booster or draft relief is the one on top of the spool that has no yoke or pin in it. Actuated by the finger of the draft linkage.
This page was generated in 0.062 seconds.
