Allis Chalmers model "C"
Masseynut(Australia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Masseynut(Australia) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers model "C"
    Posted: 16 Apr 2011 at 7:36am
Hi all,
        Looking at buying a tidy "C" for restoration. I am in Australia, (as you can see by the username). I have Masseys in my blood, but this thing is neat, and complete, so it looks like a good project to me.
Question is, were any of these tractors assembled in either Australia or England? This one has "Lucas" electrical equipment, (starter and gen.), but not sure about the magneto. If it was U.S.A. built, wouldn't it have "Delco" electrics? It does have a "marvel" carbi, though. Serial no. is 068568.
   Any help would be appreciated,
                                  thanks from Evan, (down under).
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 8:13am
I saw your pictures on YT , and the generator mounted with the long bolts and nuts, is not orignal equipment. The mag has been modified to a battery ignition. It looks like a made in the USA. Allis C.
Welcome, the guys will help you.
Edited by R Aiken - 16 Apr 2011 at 8:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Masseynut(Australia) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 6:06pm
Hi,
   thanks for the info. I'm not up with magnetos, as I'm a diesel fitter by trade.So I gather the maggi is probably stuffed cause it's got that coil piggy-backing it?? Are they usually repairable, or "throw away" items?
       Evan.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 6:18pm
They can be rebuilt or get a rebuilt one and use yours for the core charge.
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 12:26pm
did you buy that tractor ?- is the motor stuck ? if not change the oil & filter - put some new spark plugs in- looks like you need plug wires too- check the fuel tank for crud -hook up  a battery - check for spark   I bet it will fire up !  I have converted severl F-M. magnetos to external coils .  that looks like  whats been done  to that lucas mag. of yours. get it running first then see what needs fixing or replaced. look at other a/c tractors see if thay have Lucas mags.- generators-ect.-6 or 12 volt keep us posted
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 2:07pm
[QUOTE=Masseynut(Australia)]Hi all,
   Allis didn't use a 0 in front of serial numbers, at least not USA made letter models. That O should be a C to identify the model. If it is a 0 they may have done that in English production??? If B's were put together in England with the Lucas electrical parts, I don't know why they wouldn't have built C's the same way.
