Alternative to straight 30 oil for a diesel?
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Topic: Alternative to straight 30 oil for a diesel?
    Posted: 15 Apr 2011 at 11:35am
I should be getting my new to me 5040 delivered today.  i want to do an oil change before putting it to work. I see on the Nebraska test is was shown as straight 30 weight.  Would 15w40 be better? I use WIX filters in all my stuff and would like to use them with the 5040, unless someone has a better suggestion.
Thanks
AC - WD
JD - 650
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 2:37pm
15/40 will be fine.
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 2:48pm
I run 15/40 Motorcraft oil in my 1966 Case 930.  Rotella is another good oil, but motorcraft tends to be cheaper at Walmart.  I use NAPA (Wix) filters.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 3:08pm
I run Rotella 5-40 synthetic in both my diesel 7060 and Case TLB,they run cooler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 3:32pm
There is a 10w-30 diesel rated oil specified by Ford for the 6.7. They recommend 15-40 in them if you run bio diesel. The owner's manual for my D17D says 20w up to 90 degrees. 30w for higher ambient air temps.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 6:21pm
Yes, 15w-40 would be fine.  A good synthetic 5w-40 like the Mobil 1 diesel oil would be even better------especially if you start it often.
Mark
GTH-L Simplicity
