Whats it worth
AC190XTrescuer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Topic: Whats it worth
    Posted: 13 Apr 2011 at 6:27pm
 guy has a D 17 IV diesel everything good looking tin strait great original paint factory 3 pt hitch  probably 65- 70% rubber needs a new p-s rim 18.4-28 said it had a head gasket on it and runs fine however the guy he got it from said it might have the #1 cylinder sleeve scoured. whats it worth he said he wants about $3500. any advice what to look for. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 6:37pm
Forgot to add this but  it also has a new idea loader that goes on it but it needs a new bucket and the cylinders that tilt the bucket
What you cant get done today you can always do tomarrow, And if there is no tomarrow it was a waste of time today
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 7:51pm
With engine issues I wouldnt pay more than 2,000 to 2,500....decent unrestored Series IV's seem to bring in the 4000 range but engine problems can get super expenisve.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 6:23am
yes but it runs fines seems to give no trouble the guy  still hasnt looked at the engine to see if the sleeve is scoured and after they put a head gasket on it it seemd cherry, any way of telling the sleeve is messed up?
Jerry fl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry fl Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 8:03pm
to can do a compression check if the sleeve is messed up you will see it in the readings all the cylinders readings should be fairly close to each other
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 6:08am
ok thank for the help i will do this
