WD narrow front end
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: WD narrow front end
    Posted: 12 Apr 2011 at 6:29pm
I have a 53' WD and I am going to put new bearings and seals in my narrow front. I was wondering what size of gear poller to use to get the worm gear off of the top of shaft or is there a better way to do this?        thanks Josh Day
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 8:30pm
I think I put my WC shaft in a press at work and pushed it out. I had to make a new shaft for mine.
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 10:25am
There is a bolt on the bottom of the spindle housing that you remove then you can pull the gear and shaft straight up and out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 10:42am
For some reason I had the input steering shaft in mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 10:56am
 Probably because he said he wanted to get the worm gear out, but since he was wanting to replace the seals I figuired he was talking about the verticle shaft.
