Need an inj. pump shaft and drive gear - AC 180 |
Post Reply ![]() |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8208 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Apr 2011 at 9:58am |
I need an injector pump drive shaft and drive gear for a ROOSA injector pump DBGF637-75AF , model 1047062 ;; there are two avaliable the shaft I have is 16444 and its too long ; anyone have the other ???
Edited by DougG - 10 Apr 2011 at 10:06am |
d17brown ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: farley iowa Points: 1700 |
i have a pump from d21 rosa master, will that work
Troy ![]() Silver Level ![]() Joined: 11 Oct 2009 Location: MN Points: 75 |
if you dont find the right one i should have one i have 5 185 to choose from. let me know, 507 421 0213,
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21069 |
D21 shaft is splined and won't fit a 180 pump. You need the later (short) shaft which is from engines that the inj pump bolts directly to the front plate instead of an adapter that bolts to the front plate first, then the inj pump onto it. There's probably 1/2 inch difference in length.
Once again you,re right on it Dr. A ; just wondering if the drive gear is the same and if I can get by with just a new short shaft ????
Gear is the same.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4993 |
Is your pump seized? Dont just stick a new shaft in it thinking it just broke. I have the correct one you need from a 200 pump . I would take your 16444 on trade if you pay the ride for both. I can supply gear as well if you need one. thanks, Ed.
Edited by injpumpEd - 10 Apr 2011 at 8:06pm |
Post Reply ![]() |
