Freon (R12) Substitute?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Freon (R12) Substitute?
    Posted: 10 Apr 2011 at 7:31am
My neighbor has a coule of systems (one combine and one tractor) that are still R 12.  We are outa rat holed R 12.
Have any of you folks been using an R 12 substitute and which product has worked  best for you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 7:36am
Drain the system put 134a adaptors on pull a vacum and fill with 134a.  MACK
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 7:47am
R134 will work but you have to be careful about how much you put in it. The heat tranfer is not the same as R12 because the condensers aren't as big on a R12 system versus a R134.
Overcharge on R134 is not as forgiving as R12.
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 7:59am
What are the high low pressure on R134? Gary IN
Bob in Md. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob in Md. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:06am
Use  R134a  if you know how much system holds  80% charge is usually what you put in empty system. don't forget to add oil . I use ester 100.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:09am
Depending on the ambient temp and system type, 35-50 on the low side and 150-250 on the high side with a few variables in there. Thats for a R134 system.
There will be higher pressures on a converted system.
Biggest thing on the conversion is to get the heat off the condenser, fans, airflow etc.
That's how you keep the pressures down. You will either eat a compressor, smoke a belt or blow a line if you don't.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 9:42am
there was a product out there called "freze" 12 that was compatible with the R12
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 9:49am
I might still have a can of that stuff.
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:31am
freeze twelve is what i use , you can get it from ap air out of iowa i believe, i only use it if it is a top off if system is empty change over to 134a. most of my customers always want to do it the cheap way and freeze twelve is the quickest cheapest way to top off and works really well. my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 10:38am
thanks Matt and Troy, what is what I ws wanting to hear.
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 1:43pm
R-134a doesnt have the cooling capability that R-12 did, get some freeze 12 in a can, and keep it going that way if you are able to get some. IMHO.
Bob(FL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob(FL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 2:16pm
you might want to check ebay for R12 some people have held on to it and now not many uses anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 4:09pm
My brother has 2 30lb bottles of virgin R12. He keeps it for older cars.
200farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 4:50pm
I have a like 30 cans of freeze 12 at work. We get it from AP Air. If you need more info hit me up.
MitchB View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:00pm
We converted over to Freeze 12 and it works good.  Our mechanic buys in it bulk from somewhere.  He works on older cars too, so probably needs it for them.
Mitch & Barb in West MI
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 9:31pm
I heard a while back that licensed refrigeration guys can now buy r12 again. Somewhere I heard they brought it back. I use Freeze 12 too though. And freeze 12 with stopleak works good too.
silkwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote silkwood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 7:31pm
I have 10 30 lb. tanks of virgin R12 left from my business. I will sell at $12 per pound in 30 lb. tanks. I also have R502 and R500. I am located in eastern Iowa. Let me know if you are interested.
Edited by silkwood - 11 Apr 2011 at 8:24pm
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 9:44pm
I have used a product called "Red Tek".  Our implement dealer uses it for R12 systems that folks don't want to convert, and I have used it in my Ford Ranger system. I have had good luck with it.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 11:02pm
I've been having a problem with the F2, it keeps kicking the compressor on and off more often than should.  took out the clutch this year.  neighbor said it was because the condenser was too small for 134 and builds too much pressure.  thought about putting a second condenser in the compartment but haven't' looked that closely to see if there's room.
8050 works good on 134 however.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 11:17pm
Yer F2 may have another issue such as drier restriction or plugged condensor.My F2 has worked good on 134 for the 8yrs I"ve had it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 12:50pm
A restriction in the system would cause low pressures on each side. Do you have a gauge set to know what's going on? If there is a high pressure cut out switch thats stopping the compressor I'd be looking at over charge or not enough airflow through the condenser. 80% is the rule of thumb. If the R-12 charge is 1.0lbs, then typically the 134 charge will be .8lbs. When retrofits were common on the automotive side, I'd usually start out with 50% of the R-12 weight and add a little at a time until the system worked well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 4:12pm
i didn't think it was working right.  we've had the neighbor put his gauges on it, he said it is running a little on the high side.  We keep the condensor clean, pressure wash it every other year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:06pm
I'd clean it again and verify that the engine fan belt does not slip, or in the case of a clutch fan make sure it doesn't freewheel too much. Once you've determined airflow through the condenser is not the problem, I'd adress charge level. Wht type of expansion valve does it have? Fixed orifice or thermal expansion valve? A thermal expansion valve stuck open will run the pressures up.
Air in the system from not pulling a deep enough vacuum or not purging the charging hose (charging with 1lb cans) also causes higher than normal pressures/poor cooling.
Edited by Brian Jasper co. Ia - 12 Apr 2011 at 7:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:41pm
The problem is the evaperator is caked over on back side from dirt getting past cab filter. When it gets pluged. air don't pass through it and the temp. control thinks it is freezing and shuts the compressor off. Drop door down under evaperaror remove two screws and remove fan. look up just above windshield and i'll bet the evaperator is pluged with dirt. Get a short wire brush and clean it off while it is dry. Don't crank it up and try ac befor cleaning or you will have mud to work with.
  A common problem on gleaner combines.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:14pm
Mack, I said condensor, i meant evaporator.  we take the pressure washer inside the cab every other year and when we do we take the heater core out to get a better shot at the evaporator.  we even replace the temp sensor.  i would bet it's overcharged or has air.  thanks again.
bluebanshee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluebanshee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:37pm
I got 2 tanks of HotShot 414b (replaces a few types, including 134a) at a farm auction. Seems that would be a fine alternative?? Haven't used it yet as I have a full tank of r134a. I'd bet they had been using it in their IH 10XX tractors.
