1300 Field Cultivator ?
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 1300 Field Cultivator ?
    Posted: 08 Apr 2011 at 9:37pm
I took all (4) of the axle stub shafts off a few months ago to put new bearings in and give them a coat of paint.  Two have zerks in the outer cap and two have zerks on the backside of the hub.  I did not take notes and now I cannot remeber which went on the main frame and which went on the wings.  Could somone shed some light on this for me?  Mike
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 9:55pm
Kind of a question? any chance one set is four bolt and one set is six bolt? my IH cult is that way so thought maybe the AC was too.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 11:19pm
Michael WI, - sounds like something I would do also.  You might look to see if there is a close shovel on either side of the hubs?  Perhaps, they mounted the hubs in such a way as to minimim dirt being thrown towards the grease zerk.  If so, then if the hub has a grease zerk on the outer side, the closest shovel to that hub would be positioned next to the inner side of the hub & visa versa.  That is just my guess??   I have one that I can look at more closely tomorrow and let you know if I see otherwise.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 7:03am
Hubs with zerks on the backside would go on the wings so you can grease with wings folded up.
