7080 or 8070 2WD
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Topic: 7080 or 8070 2WD
    Posted: 08 Apr 2011 at 7:19pm
Which one pulls in the field better I know the 7080 was rated more but lets here some field confessions.
210,220,7010 AC,7020 AC,7040 AC,7045 Pedal Tractor, 8050& 8070 and Parts and Pieces of Many More!!!
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 8:09pm
We've owned both and if they are weighted correctly they will pull the same. I always felt that the rosa-master pump had a faster gov. reaction, and the ambac pump gave the engine a little wider torque curve, but both live longer if operated in the upper rpm range. The 8070 will easily put out more hp on the dyno. Ours were weighted right at 20k with duals,weights, fluid. The 8000 series is a lot better place to spend long days., Mike
This page was generated in 0.079 seconds.
