unstyled hood
archuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archuck Quote  Post ReplyReply Direct Link To This Post Topic: unstyled hood
    Posted: 08 Apr 2011 at 7:10pm
I'm new to AC and have a ''38'' unstyeld WC and would like to know what the extra holes in front of ware the exhaust comes out the side are for? any pics and discritions would be helpful.
                  thanks chuck in CT.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 7:16pm
The gas starting tank gose there. They used gas to start and warm up before switching to keoriesene.
Post Options Post Options   Thanks (0) Thanks(0)   Quote archuck Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 7:39pm
is thare a hood without this hole or do thay all have the holes.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 6:15pm
Only the distilate tractors had the holes. Yes there are some without the holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 12:12am
OK now y'all gots me confused. Does that mean that if I can find a starting tank for mine that it will run off of distillate? Would I have to make any modifications to mine? Is the distillate model harder to find than the non distillate?
Didn't mean to hijack this post it just got me thinkin.
Shea Mary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shea Mary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 3:23am
I also think so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 8:48am
New starter tanks are being made. If you have the original low compression engine, it would run OK. Most engines that have been worked on in the last 30 years would likely have a higher compression ratio. I never knew of a gas unstyled WC. I would think the hoods without the starter tank hole would be hard to find.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 6:52pm
I've never seen an unstyled WC without a starter tank or at least the mounting holes. I doubt your WC is still low compression, it more than likely has been overhauled at some time in it's life and upgraded with WD pistons. Another thing, your exhaust manifold may not be the original cold fuel one.
medanum6298 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote medanum6298 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 10:55pm
Thanks you for the post.
Hi guys, Im a newbie. Nice to join this forum.
