190 XT
cjammer530 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cjammer530 Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT
    Posted: 08 Apr 2011 at 9:05am
Hey guys,
It has been along time since I have posted here.  Glad to be back.  We just bought a 190 XT 1966 model with 5000 hours on it. Real clean tractor all there.  I call my local dealer in Manhatten, MT to inquire about the relieability of the tractor and was told it had a weak differential (rear end) LOL.  Any information about this model would greatly be appreciated.
Thanks
Chuck 0 Western Montana
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 12:18pm
The 1st 190s had a 2 pinion dif that did prove to be a weak point. They were campaigned by AC and were all to be upgraded to the 4 pinion differential but we do see an occasional one that slid by even to this day. Yours is most likely the 4 pinion style which was plenty strong.  Great tractor, don't shift the trans gears while rolling (use the Power Director clutch instead) or it will eventually start jumping out of gear.  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 9:51pm
Rats!  I think mine still has the 2 pinion diff!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 9:59pm
Hey Chuck it has been a long time! Welcome to the 190 club!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 10:17pm
Isn't there a way to tell by the rear axle diameter if it has the upgrades or not?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 10:24pm
Mike I'm not sure about updates, but I think the larger factory axles looked like mine.  Notice the "humps" on the end of the axle housings.....I assume they were needed for larger bearing for larger axles.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 6:30am
Small axles (2 3/4") or big axles (3 1/4") makes no difference. Before serial number 23000 it could have a 2 pinion (factory) or an added four pinion differential. Effective 23001 and up are all four pinion (Series 3).
wayne3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 7:25am
  My 190xt gas has the bigger axles. What size plow ,model, recommended? If you had smaller axles, what plow would a person use? Should a person not plow?
pdub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdub Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:33am
I know you have been asked a thouand times but how hard and expensive is it to replace third in a 190xt
pdub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdub Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:35am
how hARD and expensive to replace third gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 8:52am
Replacement of 3rd gear and coupler and collar requires COMPLETE teardown of the rearend of the tractor including removal of rear wheels and axles. A shop equipped to work with the spltting stands, fluid filled tires, jacking up the platform/cab, etc would say it's probably a 3 day (24 hrs) job.
