16" round spoke wheels for WC
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Topic: 16" round spoke wheels for WC
    Posted: 07 Apr 2011 at 8:46pm
   Did Allis or F+H ever make  16" round  spoke wheels for a WC, or just the 17" wheels????
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 9:16pm
Just 17" on the first 23,000.
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 9:29pm
Dont know years of productions but they did use16 inch and 17 inch F&H round spokes on WCs. Have had many sets of each over the years also there are the front steels that got cut down and had what ever wheel welded back on.
 Phil
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 11:24pm
Parts book for the WC tractor shows 17" spoke wheels used on the WC tractor prior to serial number WC 23529.  After that serial number the book shows 16" solid wheels.  These went from 6 bolt to 5 bolt at serial number  WC59628.
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 6:04am
I have seen 16" F&H on WC's as well. The hub is the same as on 17".
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 6:08am
So, they went from steel spokes, to 17" spoked rubber, to 6 bolt 16" solid rims, to 5 bolt 16" solid rims?   Is that correct?    I just picked up a set of spoke fronts that have 16" rims on them, so I believe they are steel cutoff wheels.  I am looking for the bolt on endcaps if anyone has a set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 11:05am
Chuck, It's pretty easy to tell if the 16 inch rim is original to the hub. When F&H made them, the spokes were "riveted" to the hub and rim. If the rims have been replaced, you can see they have been welded. I think many of the round spoked front wheels have had 16 rims welded on because tires were easier to find.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 12:13pm
All the 16" WC spokes I have persoanlly looked at  were cut offs.  As Charlie said look where the rim meets the spokes, see a weld? It aint factory. Too bad as I think the 16" cutoffs look very nice on them.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 12:51pm
I have seen factory round spoke wheels that would have fit a WC, but I don't know who they were originally built for., maybe IHC?
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 1:26pm
I've got a set of 16 inch round spokes for my WC. factory rims, rivited, not welded, can't remember the F&H number, will check when I get home.
More than I need
70Standard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 6:20pm
If anyone has a set of 16" F&H round spokes or a good looking set of cut-downs for a WC for sale, please let me know.  Mine still has the 17" round spokes, but they need repaired, and there's nothing but motorcycle tires or temporary car spare tires that will fit.  I can't imagine those looking too good on a tractor...
Roof Palomino (SN 224), Chetech Pug UTV, Three Green Tractors and one Red Tractor.
