gas tank cleaner |
Post Reply ![]() |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9562 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Apr 2011 at 4:48pm |
Has anyone ever used a mix of purex and vinegar to clean old gas out of a gas tank. I was told this by a radiator shop. I power washed the tank but it still has old gas smell. I will say that all but the very bottom came clean and shiney with no signs of rust. right in the bottom is old gas stuck like varnish. |
allis restorer ![]() Silver Level ![]() Joined: 05 Dec 2010 Location: Rib Lake, WI Points: 184 |
You could try carb cleaner, just my thoughts. Steve
Go orange or Go home!!
Gary in da UP ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Oven cleaner should dissolve it to the point you can hose the residue away with water, use acetone to remove the moisture.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2078 |
I think Phosphoric acid is what came in the Kreem kit that I used on my B. It worked really well but it might go too far for what you want to do?
Edited by wjohn - 06 Apr 2011 at 5:42pm |
Post Reply ![]() |
