Looking For...
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Topic: Looking For...
    Posted: 05 Apr 2011 at 9:51pm
I am looking for a set of front axle knees/spindles for my 180D.  I thought I had a pair located but they were only able to locate 1 of them and I really need 2.  Knees from a 185 are the same so if anybody in my area has a set please let me know. I am located in SE MN, but would be willing to travel a little bit if the price was right.  The salvage yards I have tried want an arm and a leg for a pair.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:37am
What is wrong with the one's you have? If it is the bushings I would have a machinist build some new bushings to fit in the wore knee's, then they would be nice and tight again. used knees can be wore out the same as what you have? just thinking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:45am
Well, mine, the bottoms are worn badly, must have worn through the thrust washers, and then it started wearing on the bottom end of the tube, and they are nowhere near level on the bottom, so I can't add any thrust washers to tighten them up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 11:18am
Found a pair today, for a decent price with spindles.
