6 volt to 12 volt for radio
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: 6 volt to 12 volt for radio
    Posted: 05 Apr 2011 at 6:09pm
I have a 6 volt WF  and a twelve volt radio that i would like to have on it. Is there some sort of converter to make 6 volt into 12 volt ?  OR   could a 12 volt generator or alternator work without changing all the parts ???  Thanks J
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 7:12pm
There may still be suitable 6 volt in, 12 volt out DC to DC converters. I built one back about 1968 with a couple power transistors, power diodes, and a toroid core wound with 12 gauge wire.
Besides voltage solid state radios are picky about polarity, another complication.
It is possible to convert a 6 volt tractor to 12  volts usually takes a battery, a new voltage regulator, sometimes a 12 volt generator, though electrically a 12 volt alternator performs better, new lamps, new ignition coil or a resistor for the old one, and conversion to negative ground. Lots of trouble for a radio. You might find a 6 volt radio for an early 60s vintage car in the junk yard but that's a long shot.
As a simplified alternative you could install a battery box with a small battery (say garden tractor size) just to run the radio and charge it in the shed overnight before neediing the radio. Or just carry a transistor radio. My pseudo ipod has an AM FM radio in the tiny package from SanDisk called a Sansa.
Gerald J.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 9:04pm
why not buy a set of peltor radio ear muffs ?? 40 to 55 bucks and they would sound better then a fender mounted radio and way cheaper then converting 6 to 12v.
160 CA 920diesel 5020 HD-3
