D 17 rear end gears
bubschooley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bubschooley Quote  Post ReplyReply Direct Link To This Post Topic: D 17 rear end gears
    Posted: 04 Apr 2011 at 5:35pm
Is D 17 diesel rear end gears the same as wd45 diesel rear end gears?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 6:38pm
If you mean are they the same ratio I'm not sure. If you mean will they interchange I don't think so.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 7:12pm
The matched ring and pinion set fot the WD-45 Diesel and the D-17 (prior to S/N 38899) have the same part number; 245766 according to my WD-45 and D-17 Parts books.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 7:16pm
Mitch says that putting D17 rear gears in a WD45 is a common upgrade for pullers. He also said if I wanted higher ground speed on my D17D to swap in a WD45 ring and pinion.
