Need some pointers on WC
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Need some pointers on WC
    Posted: 02 Apr 2011 at 6:36pm
The WC that I picked up last fall that I finally got running, I have taken out two or three times for rides in the backfields.   Each time I take it out, starts right up and purrs perfectly.   Drive it out of the garage and out to the back and it usually runs for a couple minutes and then it dies.   Try starting it again and it runs good, but when you try to put it in gear it dies again.    Leave it sit for awhile and start it back up and it's ok again, but if I run it for too long, same thing.  The carb I have cleaned once or twice, didn't notice anything in there for junk.   Sediment bowl has been getting some crud in it from the tank, as I'm sure it could use a good cleaning.    But I don't think it's fuel related, because it will run fine until I start to work it by driving and then the problem comes about.   I haven't gotten the electrical system diagnosed, so right now I just have a jumper going straight from the battery to the coil with alligator clips.
I even tried changing out coils to see if that did anything but nothing different.  Points are clean and I took the cap off and cranked it over and had good spark between the points.
Would love to hear some advice on what I am overlooking.   Funny thing is when it runs, it runs perfect.   It's not like when you have a carb set wrong, or it is dirty and doesn't want to let fuel up properly.   It starts like a champ and runs great, just dies after about 5 minutes of driving and then seems to not want to run right until it completely cools down, like something ignition related is getting too hot.
Edited by ChuckLuedtkeSEWI - 02 Apr 2011 at 6:37pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 6:48pm
I would have said not getting fuel until your last sentence about having to cool down to run right. One of my WC's has a gas cap that fits to tight and if I don't run it loose it will run for a couple minutes and die and then start up again and run for a little bit and die.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 6:49pm
Have you changed to a different coil yet and tried it?? That is what it sounds like as it heats up to the point that the circuit breaks until it cools back down to start again. Might try a condensor next, or first, and see if that does anything. HTH.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 7:09pm
Could be trash in fuel tank restricking flow . Fills carb runs and when pulling requires more fuel and starves out. Sets and carb refills.
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 7:31pm
Replace your condenser use a canning jar with fresh fuel and try it, to eliminate fuel tank trash and sediment in the bowl. please keep us updated Have you checked the needle in the carb?... if not, pull it out and clean the heck out of it, put it back in...
8fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8fan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 7:54pm
Sounds like stuff in the tank to me. Have had the same problem in the past, then just cleaned the tanks before using. Rust and stuff plugs the hole in the tank. When you shut it off, it kinda loosens up, and moves away.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 8:10pm
its the condensor.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 8:32pm
Originally posted by ChuckLuedtkeSEWI ChuckLuedtkeSEWI wrote:
...I took the cap off and cranked it over and had good spark between the points.
Should be VERY LITTLE spark between points.  big spark here means either bad condenser, bad coil ground, or coil connected backwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 8:34pm
Chuck I don't know if this is it but my 60 D-17 was doing exactly what your WC is doing.Finally found chunk of crud in gas tank outlet above sediment bowl.Just enough for it to run a while until it needed more and was starved.Cleaned it and tank out and have not had a problem since.May not be same problem but is easy to check.Take fuel line loose at carb and see how good of a flow you have. Just my 2 cents
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 9:34pm
Ok, I will check on a few things.   I have a small gas tank off of a snowblower that I can rig up to isolate the fuel system.   I will take the carb off one more time and doublecheck things.   If I try and replace the condenser, where is a good place to buy one?   I have heard on here that some people have been getting bad condensers so I would like to avoid that if at all possible.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 9:38pm
like Pat said, but leave the fuel run for 5 minutes, to be sure that a blockage doesn't occur. Bob
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 9:42pm
Another place to test is the carburetor inlet adapter screen. It gets clogged with grunge and varnish and won't let fuel pass to run with a load, but will let fuel run to idle and when the engine starves, it takes a while to get enough in the float bowl to run again.
One test for that condition is to pull the choke on when its dying. If it picks up for a few seconds its fuel starvation.
Another test is to pull the drain plug from the float bowl, and see if you can sustain a flow bigger than a pencil lead. Should be bigger that. There will be a major flow of maybe a cup. If it just drips after that there's a clog in the inlet screen, the pipe, the sediment bowl and its screen, or the screen in the tank and it can be some of all of the above. The pipe can have accumulated varnish until it just barely flows.
It can also be coil, condenser, or wiring or gas tank cap, though usually it takes 10 to 15 minutes for the non venting cap to show up. You can check that by loosening the cap when its stopped and quiet. If there's a vacuum, when you loosen the cap, its not venting. Vintage tractor gas caps nearly always contain the vent that's necesary to get fuel out of the tank and a cap from modern vehicles seals tight.
Gerald J.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 7:27am
This is a great site for advice!!! I think Gerald J sumed it up the best, as confirmed by others Roll on WC!!
Richard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 9:04am
I had a '55 Chevy that would run like a rabbit, then die just like you turned the key off.  Finally isolated it to the rotor.  Once when it died we removed the distributor cap right away and observed the rotor center contact in a 'down' position, but it was rising back to a normal position.  The rotor was replaced and that took care of the problem.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 5:58pm
make sure you don't use a fuel filter from a car.cars have fuel pumps,gas tractors don't.gas will hardly run through this big filter.i use a small,clear filter from a snapper riding lawn mower.it stopped the stalling on my wc.
