G hood |
Post Reply ![]() |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Apr 2011 at 11:47am |
I's always been somewhat of a pain to reach up under the hood on my G to hold the 5/16" nuts while turning the bolts from the top with a large screw driver.
So I spent most of yesterday designing, making a pattern, and producing a pair of straps to replace those nuts. I was pleased enough with the outcome that today I made another pair. If anyone has the hood off their G and will be putting it back on in the next few days, would like to try these, for the cost of shipping I will send this second pair. Dusty
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4726 |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Joe, I like the river nut idea. I have a kit, the tool and some different sizes of rivet nuts. I thought of using it but if I remember right the largest is 10-32, which I've used up, and didn't know there are larger ones.
Looking at the spec. charts you would have to us the 1/4-20, or have to drill the base/end piece out to 1/2" in order to use the original 5/16" bolts. And I sure would use some anti-seize. A little rust and I would think those rivet nuts would spin. Then how do you get them out? Dusty
Dusty, you can get them up pretty big, I went with 1/4-20 a stainless bolt and a small polished stainless flat washer. I do keep anti-seize on them and just snug them down. I had one come loose once, you just have to carefully grind the head off.
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
I riveted 1/4" nut plates on mine.
Post Reply ![]() |
