thinking outside the box again
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: thinking outside the box again
    Posted: 01 Apr 2011 at 6:47pm
but need some help in brain storming it through.chevy head is 22 inches long 8 1/2 inches wide 226 /201 head 7 wide 21 long but they are some things in the right places
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 7:36pm
What about head bolt locations? Seems like they aren't concentric. How about a 460 Ford head? The 351M-400 are kind of inbetween physical size of a 460 or Windsor style head. The Cleveland style heads are known for pretty good flow numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 8:18pm
Originally posted by Brian Jasper co. Ia Brian Jasper co. Ia wrote:
What about head bolt locations? Seems like they aren't concentric. How about a 460 Ford head? The 351M-400 are kind of in between physical size of a 460 or Windsor style head. The Cleveland style heads are known for pretty good flow numbers.
  that's is what i am needing help with is if they are another manufactured  head closer in physical width and length head bolt location isn't a problem . I will just drill and tap the deck for the head.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 10:03pm
I have some Cleveland heads I can measure but no loose WD head to compare to.  Also have a cracked one you could have for comparison if you were closer.
Edited by Jordan(OH) - 01 Apr 2011 at 10:06pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 6:57am
Tractor pulling is about the money you put in it ,the power you get out , RIGHT ? Why not just start with a big chunk of material and make a head ,they do make machine's to do thing's like that .LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:05am
measure one up see if its close to 7 inches wide 21 inches long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:37am
7-1/8 wide, 19-3/4 long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:38am
thanks its to short.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 11:08am
If you could find a 460 D0VE head commonly called a "dove" head, those are the best flowing 385 series head short of a Boss 429...
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 11:09am
I know you must be building a puller, but I've thought about how to convert the Allis 226 engine to a diesel. If the gas head could be modified to mount diesel injectors or if another head could be found to be bolted to the block. Just more of my day dreams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 11:36am
drill out the 14mm plug holes and install a injector
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 12:01pm
I was wondering about how that would work. Are there injectors that screw in or are they all held in with a plate with two bolts? Would also probably have to up the compression ratio inside the engine. How much compression could the stock internal parts, rods, cranks, pistons handle? Adding a turbo while at it would be a given as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 12:12pm
well i tried 15.1 comp on the buda rods at a little over 400 cubic inches and they didnt like it but mack says if i had them flame hardened to a 40 rockwell they wouldnt have bent. i guess it just depends on the injector you are looking at.
