HD7 Filter part numbers???
JRJRFM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRJRFM Quote  Post ReplyReply Direct Link To This Post Topic: HD7 Filter part numbers???
    Posted: 01 Apr 2011 at 5:30pm
Can anyone supply the current NAPA or other numbers for engine oil filters, and fuel filters for the HD7 Diesel? The engine is a detroit 3-71 Thanks!!!
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 8:52pm
 I went through this about a year ago on my 7, I had a dickens of a time because someone had installed the wrong fuel filters and there are some that look right but are not. I finally got it figured out and the numbers are current, the originals were the sock type and have been updated. I have to do a bit of research but I will get the fuel filter numbers for you. Tad
Check out my HD7
http://www.youtube.com/watch?v=T1KGvx55kjc
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 5:49am
The 371 oil filter #5572425  by pass P-117 or  5573014 full flow PF-132
 FUEL FILTER 5192854  6"   or  5178982  4"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 11:48am
Wix oil and fuel filters, drop the first digit from the Wix to get the Napa number,
Oil  -51005
Primary Fuel   -33061
Secondary Fuel ser#17478 up  -33511
Secondary Fuel ser#17478   -33043
If I recall correctly there are gaskets (quad seals) for the filter to base along with gaskets for the cup (they should be included with the filter) and there should be a spring and washer assembly to retain the filter inside the housing on the secondary filter, be very careful on the primary, there is one almost exactly the same but a bit longer by about .250, it will crush the filter when installed. Hope this helps Tad
Post Options Post Options   Thanks (0) Thanks(0)   Quote JRJRFM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 11:36pm
Hi! Thanks for all the info! I just got the replacement hydraulic pump installed and serviced the transmission and final drives, so now all she needs is an oil and filter change so I can take her to this years military show in western Idaho!!Here's a link:: http://p8.hostingprod.com/@imvpa.idahomotorpool.com/pictures/flyer10mvpa.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 9:21pm
When you are all said and done I am sure we would all like to see pictures of the event. Does you 7 have the Baker blade or the Garwood? Thanks Tad
