allis B won't start
tpieman22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tpieman22 Quote  Post ReplyReply Direct Link To This Post Topic: allis B won't start
    Posted: 01 Apr 2011 at 3:09pm
I have an ALlis B 1940 model have good spark. carb is clean an gas is runnin out the carb. Tried choking tried closeing gas off an still nothin. I timed the fairbanks morse mag It clicks an fires (good spark on #1 plug) The valves (pushrods are properly adjusted). I even tried ether just a little smoke puff out the exhaust , no pop or anything. the click is on #1 just as the FIRE mark appears in the flywheel hole. Yes it has compression, any ideas ? I will pull it if I have too .  does the timing sound right?
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 3:32pm
You may have the mag set to fire on the FIRE mark but at Top center compression stroke on #4 cylinder instead of #1. Check to see that when #1 plug fires it is near #1 top dead center on the compression stroke, not top center on the exhaust stroke.
Bill B
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 3:34pm
The 1950 I bought outside Baltimore did not want to light off for anything. Had gas, good spark, timing and compression. Ether just made puffs.
Finally took the carb off and shot ether into every vent, jet and passage. Reassembled, gave it a shot as it cranked, and it lit off and ran like a top.
Why? I have no idea, but I had tried everything else......
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 4:53pm
This gas today is terrible if it goes unused for a while. It will plug ports very easily. Since I started using AvGas several yrs ago I've had zero fuel related issues no matter how long something sits between starts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 5:15pm
Av gas is great stuff, good for a long time, but wow, I'm paying over $4.50/ gallon for my airplane now.
Bill B
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 7:41pm
Hello tpieman     Pull the mag and turn the imput 180, and retry.  If not bring #1 up on compression,  get #1 spk wire on mag to fire and install.   NOW please repost findings, or what the problem was for us armchair mec#$%hanics!!!!   Good luck
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 9:19pm
If when cranking it over and stop at the click and it is at the (FIRE) line in the inspection hole you are 30 degrees off. It needs to be at (CENTER or TDC) at that point. The mechanical advance moves to the fire line when running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tpieman22 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 8:28pm
welll!!!!!!!!!!!! still not running I have a good blue spark an it is timed now on #1 at top dead center. still not even one pop. can u ask to trade parts on here? I have some allis B brake shoes an parts I would like to trade for the early hand brake type is that permissable?be nice to have brakes when I pull it. Also did the original crank handle have a bolt on the end or did someone modify this crank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 8:34pm
Well if you have spark at TDC on the compression stroke all you need for it to run is fuel in there.
Yes there is a classified section for wanted and for sale items.
I think the cranks had a straight pin to catch on the pulley. It may have been knurled or swedged to fit tight.
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 9:37pm
 Feel lucky?  Pull it to a hill and coast start it in 3rd with  no one or thing ahead of you. You can pull the throttle back  and compression brake  down the rest of the hill and then drive it back in 1st......
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 8:33am
You may have a valve sticking open.  Put your hand over the carb inlet and crank the motor. the vacuum should be very strong on your hand.
Bob, North Carolina
1949 B
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:50am
sounds like your 180 dgs. off to be sure your timed right -remove plugs -valve cover-bring  tdc mark up both valves should be closed [rocker arms will be loose] check  mag [points should be open -rotor should be pointing at the timing lug in the mag. cap. also when starting move throdele open 3 or 4 notches
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 12:17pm
I don't see a reason to pull, if it won't start, there is a prblem that needs to me fixed.
Have you hand cranked it with the valve cover off watching for correct valve operation?
Is there compression?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tpieman22 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 6:57am
Well I have a split tractor in the driveway now matching the two other halfs (one given to me the other I had bought but has a cracked block. After some blisters I checked the compression 35, 20,0,0,. Have the block being boiled had one broken cam follower, one bent pushrod and stuck rings. The waterjacket side of the liners were severly pitted on two of them. The machine shop said they will turn the crank down for me. I have a manual from tractor supply. It shows the brass shims to set the bearings back to correct clearance on rods and mains. Is this really necessary? They said the crank turning people like to supply the new bearings. I am a little unsure how bearing crush enters into this. Low compression is the first thing to check ...not the last
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 10:58am
You need new bearings to match the size the crank is ground to, and the caps should all be mounted and measured before putting a bearing in,to figure out if shims have been removed or need to be added.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 11:08am
Just in case you're wondering...
The reason AV gas works better is due to no ethanol. It may also have something to do with being a higher octane. But it's my personal belief non-ethanol gas starts easier. It doesn't gum up and I've heard that it doesn't burn as hot or light off as easy as straight gas.
