C starter
8fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8fan Quote  Post ReplyReply Direct Link To This Post Topic: C starter
    Posted: 31 Mar 2011 at 10:03am
   I have a Model C with a working starter. The cgarging system works no more, and I have taken the generator off. Ca n I put a 12 volt battery on just to start the tractor about once a week during the summer, or will it ruin the starter. It starts right up, so it wont be cranking much.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 10:05am
It should be fine if you don't overdo it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 10:31am
My WD45 has worked for years with 12V on the starter. Just give a couple minutes cooling time for every 5 seconds of cranking.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 10:59am
I've had a 12 volt system on my C for 25 years. the started is still original.  Just don't crank till smoke comes out and you'll be fine. If it don't start in 15 seconds of cranking stop and let it cool down. Delco starters used on aircraft actually have a published cool down requirement. after 10 seconds wait 30 seconds. after a second 10 seconds wait 10 minutes after a third 10 seconds wait 30 minutes and contact a mechnic.
Edited by Dakota Dave - 31 Mar 2011 at 11:02am
8fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8fan Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 11:10am
Thanks guys. 1 last question. When hooking up the 12 volt battery, do I ground the positive, just like the 6 volt battery? Or, hook the positive to the starter?
Again, thanks for the answer.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 2:33pm
The starter does not care if you use + or - ground, it will crank the same either way.
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 3:08pm
Consider going negative ground, just like cars and trucks. that way you can easily add a 12V alternator, later.I put a 'newer' CS130(mid 90s?) series on my D-14. It's smaller in diameter than the older style ones(80s).Has an oval shaped connector for field and idiot light wires as opposed to the 2 prong job of the old stuff.
Also if you have to boost it, you don't have to worry about sparks flying.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 8:38pm
You don't have to change to 12 volts if the 6 volt battery works for starting your tractor. I have 2 tractors, 1 with battery ignition, that I run 6 volt batteries and the genny doesn't charge. I just charge then about twice a year. The one with battery ignition ios my mowing tractor and gets used a lot. Bob
This page was generated in 0.110 seconds.
