Narrow front C steering problems.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: Narrow front C steering problems.
    Posted: 30 Mar 2011 at 5:15pm
I have my Dads C here and the front end has a bad case of the wobbles. The worm gear in the steering box is part of it but the front end is really loose right at the pedestal. Is there an adjustment or am I going to have to replace parts? I may try and tear into it this weekend and would like to know what I am getting into. Thanks.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:26pm
First check your wheel bearings and tire pressure. You can take off the pedistal and remove shims to tighten it up. You may have to take out the pedistal shaft and change bearings and races. the side steering shaft can be shimmed to incerase gear engagment. and the steering box could be one of two types. The ross boxes usually need new pins and the gemmers usually need the comb gear welded up and reshaped. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 7:12pm
Thanks Dave. I put on my list of things to do for the weekend. Hopefully the weather holds out.
